2020 MakeX Starter Smart Links Kit
SKU:
P1090024
Weight:
2.55 KGS
EAN:
6928819510586
MakeX 2020 New
  • 2020 MakeX Starter Smart Links Kit
Description
• What is 2020 MakeX Starter Smart Links Kit?
This is a complete competition kit designed for contestants participating in the 2020 MakeX Starter Smart Links. It includes the materials necessary to complete the competition, such as mBot Chassis, Bluetooth Remote, High-speed Motor (designed for use in robotics competitions), LED Matrix, Me RGB Line Follower, Me Ultrasonic Sensor, and 9g Micro Servo.
Specifications
Packing Method
Box Packing
Package Dimension
H/W/L
427*312*75 mm ; 16.8*12.3*3 inch
Gross Weight
2.55kg
Part list
1 x LED Matrix
1 x RGB Line Follower
1 x 9g Micro Servo(Metal Gear)
1 x RJ25 Adapter
6 x RJ25 Cable
2 x Geared Motor DC 6V/312RPM
4 xBracket3*3*120°
3 xBracket3*6(blue)
3 x Bracket U1
4 x Plate 45°(blue)
4 x Triangle Plate 6*8(blue)
3 x Plate0324-072(blue)
3 x Plate0324-088(blue)
4 x Beam0808-136(blue)
4 x Slide Beam0824-016(blue)
4 x Slide Beam0824-032(blue)
32 x Nut M4
50 x Screw M4*8
30 x Screw M4*14
6 x Plastic Spacer 4*7*10
4 x Brass Stud M4*16+6
4 x Beam0412-036(blue)
1 x Mainboard mCore
1 x mBot Shell
1 x Screwdriver
1 x Wrench 5&7
2 x Mini Wheel
8 x Lock Nut M3
2 x Velcro Sticker Pad
4 x Self-drilling Screw M2.2*9.5
6 x Screw M3*25
4 x Brass Stud M4*25+6
1 x USB Cable
1 x Ultrasonic Sensor
1 x Bluetooth Module
4 x Plate 3*5*120°(blue)
4 x Beam0412-044(blue)
4 x Beam0412-060(blue)
1 x Bluetooth Controller
2 x Lithium Battery
1 x Bluetooth Dongle
1 x Shallow Tray Cyan Blue
2 x Wheel
5 x Bracket 3*3(blue)
4 x Square Beam0808-136(blue)
1 x Micro Switch B
4 x Plate 7*9-B(blue)
2 x D Shaft 4*56mm
4 x Shaft Collar 4mm
2 x Shaft Connector 4mm
6 x Cuttable Linkage(blue)
20 x Flange Bearing 4*8*3mm
2 x Tyre 68.5*22mm
34 x Lock Nut M4
24 x Plastic Rivet R4060
30 x Plastic Rivet R4120
20 x Plastic Ring 4*7*3mm
20 x Screw Headless M3*5
2 x HEX Allen Key 1.5mm
View AllClose
