Bluetooth Dongle_EN
SKU:
P5010002
Weight:
0.04 KGS
UPC:
193122000321
EAN:
6928819507630
  • Bluetooth Dongle_EN
Description
 What is Bluetooth Dongle?
Makeblock Bluetooth dongle is a BT4.0 USB adapter that's designed for short-distance wireless connection. The dongle has a USB connector that makes it easy to connect to the computer. Pairing with any Makeblock Bluetooth devices, the dongle allows you to download or debug programs wirelessly with less efforts. (The Bluetooth dongle supports Codey Rocky, mBot Bluetooth version, ranger and so on. But it does not support Ultimate, Megapi or Megapi pro currently.)
Features
 USB interface, plug-in directly to achieve Makeblock Bluetooth wireless programming device.
Only for Makeblock Bluetooth devices.
High transmission efficiency, low latency data transmission.
No cable needed,easy to carry and use.
Technology is more mature and the signal is more stable.
Specifications
Version
Bluetooth Dongle_EN
Packing Method
Box Packing
Product Information
G.W:0.01kg, DIM (L.D.H):5.39*2.01*0.86 cm
Package Information
G.W:0.04kg, DIM (L.D.H):12.8*8.8*3 cm
Carton Information
50pcs/ctn, G.W:4.4kg, DIM (L.D.H):53*17*33 cm
Warranty
https://www.makeblock.com/support/warranty-information
Bluetooth
Bluetooth 4.0
Host Interface
USB 2.0
Power Supply
5V
Output Power Class
Max. 4dBm
Receiving Sensitivity
-90dBm
Working Frequency Band
2.4GHz-2.48GHz unlicensed ISM band
Transmission Distance
15m(standard distance of Bluetooth device)
Part list
1 × Bluetooth adapter
View AllClose
