Intelligent Innovator Upgrade Pack for Courageous Traveler
SKU:
P1100023
Weight:
28.40 KGS
EAN:
6928819510630
MakeX 2020 New
Description
• What is 2020 MakeX Challenge Intelligent Innovator Upgrade Pack for Courageous Traveler?
This pack offers necessary upgrade parts for contestants who have been in the 2019 MakeX Challenge Courageous Traveler to complete the 2020 MakeX Challenge Intelligent Innovator. The pack includes DC Motor-37, Coreless Motor and its accessories, servo, Smart Camera, and adds in some structural parts and shafts.
Specifications
Packing Method
Box Packing
Package Dimension
H/W/L
543*150*140 mm ; 21.4*5.9*5.5inch
Gross Weight
28.4kg
Part list
4 x Slide Beam0824-016(Blue)
4 x Slide Beam0824-032(Blue)
4 x Slide Beam0824-096(Blue)
2 x Slide Beam0824-112(Blue)
2 x Slide Beam2424-424(Blue)
2 x Brakcet 3*3(Blue)
2 x Plate 7*9-B(Blue)
2 x Plate0324-056(Blue)
2 x Plate0324-072(Blue)
2 x Bracket U-B
4 x Double Gear Rack
2 x 37mmDC Motor 12V/200RPM
2 x 37mm Motor Bracket (Blue)
1 x 2824ZWW-1Z-68-11.1 Brushless Motor
1 x 2824ZWW-1F-68-11.1 Brushless Motor
2 x Brushless Motor ESC
2 x Brushless Motor Bracket
2 x Friction Wheel D45*19.5
2 x Friction Wheel Ring D28*7
2 x PH2.0 Motor Cable
2 x Smart Servo MS-12A
2 x Mounting Bracket(Blue)
2 x Rudder Bracket(Blue)
2 x Virtual Axis
2 x Smart Motor Cable-20cm
1 x Ranging Sensor
1 x 5V General Cable-20cm
1 x 5V General Cable-60cm
4 x Plastic Gear 56T
4 x Plastic Gear 8T
4 x Plastic Gear 72T
4 x Gear 48T(Blue)
4 x Gear 80T(Blue)
4 x Gear 16T(Blue)
2 x Belt Connector(Blue)
1 x Open-endTiming Belt
4 x 58mm Omni Wheel Shaft Coupling
2 x D shaft 4*200mm
2 x D shaft 4*240mm
2 x D shaft 4*320mm
2 x Shaft D8*96mm
2 x Shaft D8*128mm
3 x Flexible Coupling 4*4mm
4 x Shaft Collar 8mm
1 x Smart Camera
1 x Power Module
View AllClose
