Makeblock Neuron Creative Lab Kit 2.0
SKU:
P1030020
Weight:
2.55 KGS
EAN:
6928819507708
New
  • Makeblock Neuron Creative Lab Kit  2.0
Description
• What is Makeblock Neuron Creative Lab Kit 2.0
Makeblock Neuron is a series of programmable electronic building blocks for STEAM education. The Neuron series includes dozens of electronic modules with different functions, such as LED Panel, Ultrasonic, Motor, Servo, and various sensors. Just snap them together to create assorted innovative gadgets. With our block-based programming software and the flow-based programming software, you can activate these powerful blocks and bring your ideas to life without complex code.
Features
Easy to use but hard to get bored with
Even newbies can enjoy
Compatible with LEGO pieces and other Makeblock parts
A variety of electronic blocks, including Motor, Servo, LED Strip, LED Panel, and sensors with various functions. Program these blocks on mBlock and explore cutting-edge technologies like IoT, AI, deep learning through play
Resourceful learning materials to lead you into and through the creation journey
Software
Neuron App:
Flow-based programming app with IoT support
mBlock:
The block-based coding platform trusted by
10 million makers, educators, and learners
Specifications
Battery
Capacity: 950mAh; Life: maximum 4 hours; Charging time: appr. 75 minutes; Output voltage: DC 5V; Input voltage: DC 5V; Input current:<1A
Bluetooth
Version: BT 4.0; Frequency range: 2402 - 2480MHz
DC Geared Motor N30: Rated Rotational speed: 12000±10%RPM; Stall torque: ≥28gf·cm; Rated current: ≤85mA、Stall current: ≤0.88A
Servo
Operating voltage: 4.8V~6.0V; Idle current: 6±1mA; Limit angle: 180° ± 10
Wireless transmission
Bluetooth/2.4GHz
Packing Method
Box Packing
Package Dimension
H/W/L
427×312×75mm
Gross Weight
2.55 KG
Part list
2×Power
2×Bluetooth
1×Wireless Transmitter
1×Wireless Receiver
1×Joystick
2×Button
2×Knob
1×Funny Touch
1×Funny Switches
1×GND Wire
1×Light Sensor
1×Dual IR Detector
1×Ranging Sensor
1×Ultrasonic Sensor
1×Color Sensor
8×Codey Rocky_Colored Card
1×Gyro Sensor
1×Temperature Sensor
1× Temperature Probe
1×Humiture Sensor
1×Soil Moisture Sensor
1×Sound Sensor
1×PIR Sensor
2×Dual DC Motor Driver
2×Dual Servo Driver
2×LED Panel
1×RGB LED
2×LED Strip Driver
1×Buzzer
1×Display
2×LED Strip
1x Water Pump
1×Silicone Tube
4× N30 Geared Motor Gearbox Accessory Pack
4×Crossed Shaft Connector
4×Mini Auxiliary Wheel
4×Lego Tyre_49.5*20mm
4×Servo Accesory Pack
12×Neuron Board
72×Friction Pin Connector
3×Magnet Wire (10cm)
3×Magnet Wire (20cm)
6×Gel Pad
2×USB Cable
Resource
Introduction
Case manual
Curriculum
Case videos
View AllClose
Videos Hide Videos Show Videos
