STEAM Education Intermediate Solution
SKU:
P1010110
Weight:
129.94 KGS
UPC:
193122006095
EAN:
6928819510029
Description
• What is STEAM Education Intermediate Solution?
STEAM Education Intermediate Solution provides resources that help middle schools set up their STEAM labs and organize robotics competitions. It includes 34 boxes of components, 8 backup storage trays and 7 packs of runners and clips compatible with storage shelves. The solution can work with MakerSpace series based middle school courses, making it a perfect setup for classroom teaching (for a class size of 2-8 students) and maker education activities (for 8 - 16 students involved). Moreover, the solution can equip 2 MakeX teams with supplies necessary for the Challenge competition, and can be used in conjunction with other MakerSpace kits to increase the class and team size.
Specifications
Packing Method
Box Packing
Gross Weight
129.94 KG
Part list
MakerSpace Kits2.0-mBot Modules (P1010069)
4 x Mainboard mCore
4 x Chassis
4 x Bluetooth Module
MakerSpace Kits2.0-Electronic Modules 1(P1010070)
4 x Me Auriga
2 x MegaPi Acrylic Bracket
2 x MegaPi Pro 4DC Motor Driver
2 x MegaPi Pro
2 x Power Cord
2 x MegaPi Pro Shield for RJ25
2 x Bluetooth Module
MakerSpace Kits2.0-Electronic Modules 2 (P1010071)
2 x Sound Sensor
2 x Gas Detection Module
4 x Line Follower
2 x PIR Motion Sensor
4 x Light Sensor
8 x RGB LED
2 x Flame Sensor
4 x Color Sensor
4 x RGB Line Follower
MakerSpace Kits2.0-Electronic Modules 3 (P1010072)
4 x Micro SD Card
4 x Ultrasonic Sensor
4 x 4 Button
4 x 7-segment Display
2 x Temperature and Humidity Sensor
2 x Compass
2 x 3-Axis Accelerometer and Gyro Sensor
2 x Infrared Receiver decode
4 x Audio Player
4 x Touch Sensor
4 x Potentiometer
MakerSpace Kits2.0-Electronic Modules 4(P1010073)
2 x Temperature Sensor
4 x LED Matrix
2 x Me TFT LCD Screen-2.4 Inch
2 x Slide Potentiometer
4 x LED RGB Strip(0.5M)
4 x RJ25 Adapter
4 x LED RGB Strip(1M)
MakerSpace Kits2.0-Electronic Modules 5(P1010074)
8 x Micro Switch B
4 x Bluetooth Controller
4 x IR Controller
4 x Bluetooth Dongle
4 x Joystick
MakerSpace Kits2.0-Electronic Modules 6 (P1010075)
2 x AC to DC 12V/3A Wall Adapter Power Supply For Arduino / Meduino
4 x Adapter For 18650 Lithium Battery
6 x USB type B Cable
16 x RJ25 Cable-50cm
8 x RJ25 to Dupont Wire
6 x Micro USB Cable
16 x RJ25 Cable-20cm
MakerSpace Kits2.0-Beam0824 Structural Parts(P1010076)
8 x Slide Beam0824-016
8 x Slide Beam0824-032
8 x Slide Beamo824-048
8 x Slide Beam0824-064
8 x Slide Beam0824-080
8 x Slide Beam0824-096
8 x Slide Beam0824-112
4 x Slide Beam0824-128
4 x Slide Beam0824-144
4 x Slide Beam0824-160
4 x Slide Beam0824-176
4 x Slide Beam0824-192
4 x Slide Beam0824-224
4 x Slide Beam0824-256
4 x Slide Beam0824-320
MakerSpace Kits2.0-Beam0808 Structural Parts(P1010077)
16 x Beam0808-024
16 x Beam0808-40A
16 x Beam0808-40B
16 x Beam0808-056
16 x Beam0808-072
16 x Beam0808-080
16 x Beam0808-088
16 x Beam0808-104
16 x Beam0808-120
16 x Beam0808-136
16 x Beam0808-152
16 x Beam0808-168
16 x Beam0808-184
16 x Beam0808-312
MakerSpace Kits2.0-Beam0412 Structural Parts(P1010078)
16 x Beam0412-036
16 x Beam0412-044
16 x Beam0412-060
16 x Beam0412-076
16 x Beam0412-092
16 x Beam0412-108
16 x Beam0412-124
16 x Beam0412-140
16 x Beam0412-156
16 x Beam0412-172
16 x Beam0412-188
16 x Beam0412-188-L2-R1
16 x Beam0412-204
16 x Beam0412-220
16 x Beam0412-220-L5
16 x Beam0412-236
MakerSpace Kits2.0-Square Beam Structural Parts(P1010079)
16 x Square Beam0808-016
16 x Square Beamo808-032
16 x Square Beam0808-040
16 x Square Beam0808-056
16 x Square Beam0808-072
16 x Square Beam0808-088
16 x Square Beam0808-104
16 x Square Beam0808-120
16 x Square Beam0808-136
16 x Square Beam0808-152
16 x Square Beam0808-168
16 x Square Beam0808-184
MakerSpace Kits2.0-Slide Beam2424 Structural Parts(P1010080)
4 x Slide Beam2424-072
4 x Slide Beam2424-104
4 x Slide Beam2424-136
4 x Slide Beam2424-168
4 x Slide Beam2424-184
4 x Slide Beam2424-248
4 x Slide Beam2424-312
MakerSpace Kits2.0-Connecting Fittings(P1010081)
24 x Brakcet 3*3
16 x Bracket 3*6
16 x Plate 3*6
16 x Plate 7*9-B
16 x Plate l1
16 x Plate O1
16 x Plate A
16 x Triangle Plate 6*8
16 x Plate45°
16 x Bracket L1
16 x Bracket U1
16 x Bracket U-B
8 x Disc D72
8 x Bracket P1
8 x Bracket P3
48 x Cuttable Linkage
24 x Cuttable Linkage 3 Hole
8 x Stiffener 1616-008-M4
8 x Plate0324-040
8 x Plate0324-056
16 x Plate0324-072
16 x Plate0324-088
16 x Plate0324-184
24 x Plate 3*5*120
24 x Bracket 3*3*120
8 x Bracket U-C
MakerSpace Kits2.0-Large Parts (P1010082)
4 x Lean Beam-424
4 x Lean Beam-504
4 x Slide Beam-424
4 x Slider 496(Blue)
4 x Beam0808-504(Blue)
6 x Slide Beam0824-496
4 x Shaft D8*512mm-H
6 x Shaft D8*496mm-H
2 x 360*256mm Aluminium Sheet
2 x Base Plate- S(Blue)
MakerSpace Kits2.0-Hardwares and Tools 1*2(P1010083)
400 x Socket Cap Screw M4*8-Button Head
100 x Socket Cap Screw M4*40-Button Head
100 x Socket Cap Screw M4*35-Button Head
100 x Socket Cap Screw M4*30-Button Head
100 x Socket Cap Screw M4*22-Button Head
200 x Socket Cap Screw M4*16-Button Head
400 x Socket Cap Screw M4*14-Button Head
60 x Cross Recess Screw M3*8-Countersunk Head
100 x Plastic Spacer 4*8*1
100 x Plastic Spacer 4*7*3
200 x Plastic Spacer 4*7*2
40 x Plastic Spacer 4*7*10
120 x Plastic Rivet R4120(White)
120 x Plastic Rivet R4100(White)
120 x Plastic Rivet R4060(Black)
80 x Tapping Screw with Washer M2.2*9.5-Round Head
20 x Nylon Stud M4*30
10 x Velcro sticker pad
40 x Nylon Cable Ties1.9*100
20 x Hex Nut M8
400 x Hex Nut M4
200 x Hex Nut M3
200 x Hex Lock Nut M4
100 x Cross Recess Screw M3*25-Button Head
100 x Cross Recess Screw M3*16-Button Head
4 x Cross &2.5mm HEX Screwdriver V2.0
40 x Brass Stud M4*8+6
24 x Brass Stud M4*32
40 x Brass Stud M4*16
6 x Wrench M5+M7
8 x HEX Allen Key 1.5mm
8 x HEX Allen Key 2.5mm
100 x Headless Screw M3*5
2 x 2 Inch G-clamp
MakerSpace Kits2.0-Hardwares and Tools 2*2(P1010084)
100 x Headless Screw M3*8
200 x Combination Screw M4*8
200 x Combination Screw M4*10
200 x Combination Screw M4*14
400 x Combination Screw M4*16
400 x Combination Screw M4*20
200 x Combination Screw M4*30
400 x Combination Screw M4*35
200 x Combination Screw M4*40
200 x Hex Lock Nut M3
4 x Small Four-way socket wrench
4 x Rapid Steel Allen Driver 1.5mm(Black)
4 x Rapid Steel Allen Driver 3mm(Black)
600 x Hex Nut M4
8 x Brass Stud M4*25+6 (Pack of 4)
8 x Brass Stud M4*16+6 (Pack of 4)
MakerSpace Kits2.0-Basic Drive Parts 1(P1010085)
8 x Timing Belt 140T(112MXL)
8 x Timing Belt 300T(240MXL)
6 x Timing Belt-Open end(5m)
8 x Belt Connector-B
8 x Belt Connector
8 x Timing Pulley Slice 90T-B
8 x Timing Pulley Slice 62T-B
8 x Plastic Timing Pulley 18T
4 x Timing Pulley 90T
4 x Timing Pulley 62T
4 x Fully Threaded Rod M4*192
4 x Fully Threaded Rod M4*288
4 x Fully Threaded Rod M4*248
8 x Thread Drive Beam M4*40
8 x Sliding Block A1
32 x Aluminum Sleeve4*6*4
32 x Aluminum Sleeve 4*6*6
32 x Roller(With Bearing)
16 x Nylon Wheel( No Bearing)
8 x V-slot Bearing 4*136
4 x Slider 256
MakerSpace Kits2.0-Basic Drive Parts 2(P1010086)
4 x Gear 16T
4 x Gear 48T
4 x Gear 80T
16 x Double gear Rack
16 x Plastic Gear 8T
16 x Plastic Gear 56T
32 x Plastic Gear 72T
MakerSpace Kits2.0-Shaft Type Drive Parts(P1010087)
20 x D Shaft 4*56
8 x D Shaft 4*128
12 x D Shaft 4*160
8 x Shaft 8*96-H
8 x Shaft 8*128-H
8 x Shaft 8*312-H
24 x Shaft 4*88
8 x Shaft 4*240
8 x Shaft 4*288
8 x Linear Box Slider D8
100 x Flange Bearing 4*8*3
20 x Bearing 4*8*3
8 x Shaft Clamping Hub 8mm
16 x 8mm Bearing Bracket A
30 x Shaft Connector 4mm V3.0
40 x Shaft Collar 8mm
8 x Universal Joint 4*4
20 x Bearing F688ZZ
16 x Flexible Coupling 4*4
20 x Bearing 8*16*5
16 x Threaded shaft 4*39
80 x Shaft Collar 4mm
MakerSpace Kits2.0-Motion Parts 1(P1010088)
16 x Plastic Timing Pulley 62T
16 x Plastic Timing Pulley 90T
8 x Plastic Timing Pulley 62T For Motor
16 x Plastic Timing Pulley 90T For Motor
16 x Tyre 68.5*22mm
8 x Slick Tire
8 x Mini Caster Wheel
MakerSpace Kits2.0-Motion Parts 2(P1010089)
200 x Track
200 x Track Axle
4 x 58mm Omni Wheel Coupling Pack
4 x 1 Inch Nylon Pulley
8 x 58mm Omni Wheel
MakerSpace Kits2.0-Servos(P1010090)
8 x 9g Micro Servo Robot Pack
4 x RJ25 Adapter
8 x Smart Servo MS-12A
8 x Rudder Bracket
8 x Terminal Wire-20cm
8 x Terminal Wire 60cm
8 x Mounting Bracket
8 x Virtual Axis
4 x MEDS150 Servo Motor
8 x Color Number Sticker
MakerSpace Kits2.0-Motor Modules 1(P1010091)
8 x Geared Motor DC6V/312RPM
4 x Me 130 Motor Pack-5V/10000RPM
MakerSpace Kits2.0-Motor Modules 2(P1010092)
4 x DC Motor-37 12V/50RPM
4 x DC Motor-37 12V/200RPM
4 x DC Motor-25 9V/185RPM
4 x Optical Encoder Motor-25 9V/185RPM
MakerSpace Kits2.0-Motor Modules 3(P1010093)
16 x DC Motor-25 Bracket
16 x DC Motor-37 Bracket
8 x Dual Motor Driver
32 x PH2.0 Motor Cable
8 x 180 Optical Encoder Motor
4 x Encoder Motor Driver
8 x High-Power Encoder /DC Motor Driver
8 x 2. 54mm 6P Encoder Motor Cable
8 x MegaPi Pro Encoder/DC Motor Driver
8 x 25 Encoder Motor Cable
MakerSpace Kits2.0-Motor Modules 4 (P1010094)
2 x Air Pump Motor-DC 12V/370-02PM
2 x Solenoid Valves DC 12V/0520E
2 x Water Pump Motor-DC 12V370-04PM
2 x Silicone Air Tube 0507
2 x Vacuum Suction Head M4
2 x Silicone Air Tube 0305
2 x Vacuum Suction Cup-SP-30
2 x Mini Gripper
4 x Robot Gripper-Black
MakerSpace Kits2.0-Motor Modules 5 (P1010095)
4 x 42BYG Stepper Motor Bracket-B
4 x Me Stepper Motor Driver
2 x Brushless Motor
4 x MegaPi Pro ESC Driver V1.0
4 x Friction Wheel D45*19.5
4 x Friction Wheel Ring D28*7
4 x Megapi Stepper Motor Driver
MakerSpace Kits2.0-Motion Parts 3 (P1010097)
8 x 100mm Omni Wheel
8 x 100mm Omni Wheel Coupling
40 x Cuphead Screw M5*40
40 x Lock Nut M5
MakerSpace Kits2.0-Chain Transmission Parts (P1010099)
4 x 04C 20T Sprockets
2 x 04C 14T Double Sprockets
4 x 04C 10T Sprockets
4 x 04C Roller Chain-1.5
2 x 04 Chain Rivet Extractor
2 x 04C Half Chain Unit
2 x 04C Chain Unit
4 x 04C One-hole Bending Chain
16 x Headless Screw M3*5
16 x Headless Screw M5*5
8 x Shaft 8*96-H
8 x Shaft Collar 8mm
4 x Bracket U-B
MakerSpace Kits2.0-MakeX Electronic Modules (P1010100)
8 x Dual RGB Color Sensor
8 x Ranging Sensor
2 x Power Expansion Board
16 x PH2. 0 Motor Cable
2 x Me Power Management Module
2 x Main Board NovaPi
8 x Smart Moter Cable-60CM
12 x 5V General Cable-20cm
2 x Low Voltage Buzzer Alarm
2 x XT60 XT30/DC One with Three Power Cords
12 x 5V General Cable-60cm
MakerSpace Kits2.0-MakeX Batteries (P1010101)
4 x Lithium Battery
4 x 18650 Lithium Battery Pack
2 x FB4300HP-3SLI-PO Battery
MakerSpace Kits2.0-MakeX Motor Modules (P1010102)
1 x Skyr B6AC V2
4 x x180 Smart Encoder Motor
2 x xNovaPi Case
4 x 36 Encoder Motor-Brushless
Gratnells Shallow Tray, CyanBlue (Pack of 4)*2
8 x Gratnells Shallow Tray, CyanBlue
Lid for Standard Trays, Translucent (Pack of 4)*2
8 X Lid for Standard Trays, Translucent
Gratnells Tray Runners with Clips for Trays (Pack of 6 pairs)*7
42 x tray clips
42 x runners
View AllClose
