STEAM Education Primary Solution
SKU:
P1010109
Weight:
89.48 KGS
UPC:
193122006088
EAN:
6928819510012
Description
• What is STEAM Education Primary Solution?
STEAM Education Primary Solution provides resources that help primary schools set up their STEAM labs and organize robotics competitions. It includes 26 boxes of components, 8 storage trays and 6 packs of runners and clips compatible with storage shelves. The solution can work with MakerSpace series based primary courses, making it a perfect setup for classroom teaching (for a class size of 2-8 students) and maker education activities (for 8 - 16 students involved). Moreover, the solution can equip 4 MaxeX teams with supplies necessary for the Starter competition, and can be used in conjunction with other MakerSpace kits to increase the class and team size.
Specifications
Packing Method
Box Packing
Category
Kits
Gross Weight
89.482kg
Part list
MakerSpace Kits2.0-Neuron Sensor Block 1(P1010066)
4 x SmartPower
8 x RGB LED
4 x Funny Touch
4 x Ranging Sensor
8 x LED Panel
4 x Funny Switch
4 x GND Wire
8 x Servo
8 x DC Motor
MakerSpace Kits2.0-Neuron Sensor Block 2(P1010067)
2 x Dual IR Detector
2 x Light Sensor
2 x Sound Sensor
2 x PIR Sensor
2 x Color Sensor
2 x Temperature Sensor
2 x Soil Moisture Sensor
2 x Soil Moisture Probe
2 x Gyro Sensor
2 x Humiture Sensor
4 x LED Strip Driver
2 x Buzzer
4 x Dual DC Motor Driver
4 x Dual Servo Driver
2 x Color Identification Card
2 x Joystick
2 x Temperature Probe
4 x LED Strip
4 x EL Wire Driver
16 x EL Wire
2 x Knob
2 x Button
MakerSpace Kits2.0-Neuron Sensor Block 3(P1010068)
2 xWater Pump
24 x Neuron Board
4 x Magnet Wire(10cm)
4 x Magnet Wire(20cm)
4 x USB Cable
8 x Gel Pad
8 x Mini Auxiliary Wheel
8 x Wheel
MakerSpace Kits2.0-mBot Modules(P1010069)
4 x Mainboard mCore
4 x Chassis
4 x Bluetooth Module
MakerSpace Kits2.0-Electronic Modules 1(P1010070)
4 x Me Auriga
2 x MegaPi Acrylic Bracket
2 x MegaPi Pro 4DC Motor Driver
2 x MegaPi Pro
2 x Power Cord
2 x MegaPi Pro Shield for RJ25
2 x Bluetooth Module
MakerSpace Kits2.0-Electronic Modules 2(P1010071)
2 x Sound Sensor
2 x Gas Detection Module
4 x Line Follower
2 x PIR Motion Sensor
4 x Light Sensor
8 x RGB LED
2 x Flame Sensor
4 x Color Sensor
4 x RGB Line Follower
MakerSpace Kits2.0-Electronic Modules 3(P1010072)
4 x Micro SD Card
4 x Ultrasonic Sensor
4 x 4 Button
4 x 7-segment Display
2 x Temperature and Humidity Sensor
2 x Compass
2 x 3-Axis Accelerometer and Gyro Sensor
2 x Infrared Receiver decode
4 x Audio Player
4 x Touch Sensor
4 x Potentiometer
MakerSpace Kits2.0-Electronic Modules 4(P1010073)
4 x LED Matrix
2 x Me TFT LCD Screen-2.4 Inch
2 x Slide Potentiometer
4 x LED RGB Strip(0.5M)
4 x RJ25 Adapter
4 x LED RGB Strip(1M)
MakerSpace Kits2.0-Electronic Modules 5(P1010074)
8 x Micro Switch B
4 x Bluetooth Controller
4 x IR Controller
4 x Bluetooth Dongle
4 x Joystick
MakerSpace Kits2.0-Electronic Modules 6(P1010075)
2 x AC to DC 12V/3A Wall Adapter Power Supply For Arduino / Meduino
4 x Adapter For 18650 Lithium Battery
6 x USB type B Cable
16 x RJ25 Cable-50cm
8 x RJ25 to Dupont Wire
6 x Micro USB Cable
16 x RJ25 Cable-20cm
MakerSpace Kits2.0-Beam0824 Structural Parts*2(P1010076)
16 x Slide Beam0824-016
16 x Slide Beam0824-032
16 x Slide Beamo824-048
16 x Slide Beam0824-064
16 x Slide Beam0824-080
16 x Slide Beam0824-096
16 x Slide Beam0824-112
8 x Slide Beam0824-128
8 x Slide Beam0824-144
8 x Slide Beam0824-160
8 x Slide Beam0824-176
8 x Slide Beam0824-192
MakerSpace Kits2.0-Beam0808 Structural Parts(P1010077)
16 x Beam0808-024
16 x Beam0808-40A
16 x Beam0808-40B
16 x Beam0808-056
16 x Beam0808-072
16 x Beam0808-080
16 x Beam0808-088
16 x Beam0808-104
16 x Beam0808-120
16 x Beam0808-136
16 x Beam0808-152
16 x Beam0808-168
16 x Beam0808-184
16 x Beam0808-312
MakerSpace Kits2.0-Beam0412 Structural Parts (P1010078)
16 x Beam0412-036
16 x Beam0412-044
16 x Beam0412-060
16 x Beam0412-076
16 x Beam0412-092
16 x Beam0412-108
16 x Beam0412-124
16 x Beam0412-140
16 x Beam0412-156
16 x Beam0412-172
16 x Beam0412-188
16 x Beam0412-188-L2-R1
16 x Beam0412-204
16 x Beam0412-220
16 x Beam0412-220-L5
16 x Beam0412-236
MakerSpace Kits2.0-Square Beam Structural Parts (P1010079)
16 x Square Beam0808-016
16 x Square Beamo808-032
16 x Square Beam0808-040
16 x Square Beam0808-056
16 x Square Beam0808-072
16 x Square Beam0808-088
16 x Square Beam0808-104
16 x Square Beam0808-120
16 x Square Beam0808-136
16 x Square Beam0808-152
16 x Square Beam0808-168
16 x Square Beam0808-184
MakerSpace Kits2.0-Connecting Fittings(P1010081)
24 x Brakcet 3*3
16 x Bracket 3*6
16 x Plate 3*6
16 x Plate 7*9-B
16 x Plate l1
16 x Plate O1
16 x Plate A
16 x Triangle Plate 6*8
16 x Plate45°
16 x Bracket L1
16 x Bracket U1
16 x Bracket U-B
8 x Disc D72
8 x Bracket P1
8 x Bracket P3
48 x Cuttable Linkage
24 x Cuttable Linkage 3 Hole
8 x Stiffener 1616-008-M4
8 x Plate0324-040
8 x Plate0324-056
16 x Plate0324-072
16 x Plate0324-088
16 x Plate0324-184
24 x Plate 3*5*120
24 x Bracket 3*3*120
8 x Bracket U-C
MakerSpace Kits2.0-Hardwares and Tools 1(P1010083)
200 x Socket Cap Screw M4*8-Button Head
50 x Socket Cap Screw M4*40-Button Head
50 x Socket Cap Screw M4*35-Button Head
50 x Socket Cap Screw M4*30-Button Head
50 x Socket Cap Screw M4*22-Button Head
100 x Socket Cap Screw M4*16-Button Head
200 x Socket Cap Screw M4*14-Button Head
30 x Cross Recess Screw M3*8-Countersunk Head
50 x Plastic Spacer 4*8*1
50 x Plastic Spacer 4*7*3
100 x Plastic Spacer 4*7*2
20 x Plastic Spacer 4*7*10
60 x Plastic Rivet R4120(White)
60 x Plastic Rivet R4100(White)
60 x Plastic Rivet R4060(Black)
40 x Tapping Screw with Washer M2.2*9.5-Round Head
10 x Nylon Stud M4*30
5 x Velcro sticker pad
20 x Nylon Cable Ties1.9*100
10 x Hex Nut M8
200 x Hex Nut M4
100 x Hex Nut M3
100 x Hex Lock Nut M4
50 x Cross Recess Screw M3*25-Button Head
50 x Cross Recess Screw M3*16-Button Head
2 x Cross &2.5mm HEX Screwdriver V2.0
20 x Brass Stud M4*8+6
12 x Brass Stud M4*32
20 x Brass Stud M4*16
3 x Wrench M5+M7
4 x HEX Allen Key 1.5mm
4 x HEX Allen Key 2.5mm
50 x Headless Screw M3*5
1 x 2 Inch G-clamp
MakerSpace Kits2.0-Basic Drive Parts 1(P1010066)
8 x Timing Belt 140T(112MXL)
8 x Timing Belt 300T(240MXL)
6 x Timing Belt-Open end(5m)
8 x Belt Connector-B
8 x Belt Connector
8 x Timing Pulley Slice 90T-B
8 x Timing Pulley Slice 62T-B
8 x Plastic Timing Pulley 18T
4 x Timing Pulley 90T
4 x Timing Pulley 62T
4 x Fully Threaded Rod M4*192
4 x Fully Threaded Rod M4*288
4 x Fully Threaded Rod M4*248
8 x Thread Drive Beam M4*40
8 x Sliding Block A1
32 x Aluminum Sleeve4*6*4
32 x Aluminum Sleeve 4*6*6
32 x Roller(With Bearing)
16 x Nylon Wheel( No Bearing)
8 x V-slot Bearing 4*136
4 x Slider 256
MakerSpace Kits2.0-Basic Drive Parts 2(P1010086)
4 x Gear 16T
4 x Gear 48T
4 x Gear 80T
16 x Double gear Rack
16 x Plastic Gear 8T
16 x Plastic Gear 56T
32 x Plastic Gear 72T
MakerSpace Kits2.0-Shaft Type Drive Parts(P1010087)
20 x D Shaft 4*56
8 x D Shaft 4*128
12 x D Shaft 4*160
8 x Shaft 8*96-H
8 x Shaft 8*128-H
8 x Shaft 8*312-H
24 x Shaft 4*88
8 x Shaft 4*240
8 x Shaft 4*288
8 x Linear Box Slider D8
100 x Flange Bearing 4*8*3
20 x Bearing 4*8*3
20 x Bearing 8*16*5
16 x Threaded shaft 4*39
80 x Shaft Collar 4mm
40 x Shaft Collar 8mm
8 x Universal Joint 4*4
20 x Bearing F688ZZ
30 x Shaft Connector 4mm
16 x Flexible Coupling 4*4
8 x Shaft Clamping Hub 8mm
16 x 8mm Bearing Bracket A
30 x Shaft Connector 4mm V3.0
MakerSpace Kits2.0-Motion Parts 1(P1010088)
16 x Plastic Timing Pulley 62T
16 x Plastic Timing Pulley 90T
8 x Plastic Timing Pulley 62T For Motor
16 x Plastic Timing Pulley 90T For Motor
16 x Tyre 68.5*22mm
8 x Slick Tire
8 x Mini Caster Wheel
MakerSpace Kits2.0-Motion Parts 2(P1010089)
200 x Track
200 x Track Axle
4 x 58mm Omni Wheel Coupling Pack
4 x 1 Inch Nylon Pulley
8 x 58mm Omni Wheel
MakerSpace Kits2.0-Servos(P1010090)
8 x 9g Micro Servo Robot Pack
8 x Smart Servo MS-12A
8 x Rudder Bracket
8 x Terminal Wire-20cm
8 x Terminal Wire 60cm
48 x Mounting Bracket
8 x Virtual Axis
4 x MEDS150 Servo Motor
8 x Color Number Sticker
MakerSpace Kits2.0-Motor Modules 1(P1010091)
8 x Geared Motor DC6V/312RPM
4 x Me 130 Motor Pack-5V/10000RPM
MakerSpace Kits2.0-Motor Modules 2(P1010092)
4 x DC Motor-37 12V/50RPM
4 x DC Motor-37 12V/200RPM
4 x DC Motor-25 9V/185RPM
4 x Optical Encoder Motor-25 9V/185RPM
MakerSpace Kits2.0-Motor Modules 3(P1010093)
16 x DC Motor-25 Bracket
16 x DC Motor-37 Bracket
8 x Dual Motor Driver
32 x PH2.0 Motor Cable
8 x 180 Optical Encoder Motor
4 x Encoder Motor Driver
8 x High-Power Encoder /DC Motor Driver
8 x 2. 54mm 6P Encoder Motor Cable
8 x MegaPi Pro Encoder/DC Motor Driver
8 x 25 Encoder Motor Cable
mBot Li-polymer Battery*4(P3090003)
4 x Lithium Battery
4 x Lithium Battery Case
18650 Lithium Battery Pack*4(14026)
4 x 18650 Lithium Battery Pack
Gratnells Shallow Tray, CyanBlue (Pack of 4)*2(P4050001)
8 x Gratnells Shallow Tray, CyanBlue
Lid for Standard Trays, Translucent (Pack of 4)*2(P4050004)
8 X Lid for Standard Trays, Translucent
Gratnells Tray Runners with Clips for Trays (Pack of 6 pairs)*6(P4050005)
36 x tray clips
36 x runners
View AllClose
